First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
Please do NOT post bugs here! If you spot a potential Bug please report it HEREfirst then you can chat about it with other users in the appropriate section.
These versions are not available on the site, A user may have these available for you.
Backups are not forward compatible. The new version will not allow you to restore from a previous version at all.
If you install over the top, usually your cues will remain. I think in your circumstance that your cues are not compatible with the new release as there has been some large changes in the file system.
