Error installing MAGIC 3D Topic is solved
directsound
Post by directsound »
i GOT A new computer and I cant get Magic 3d visulizer to install I keeping gettin this error for the last two weeks'
Error opening http://.nicolaudie.com/big/Magic.exe
The server returned status code 404
can someone help me get this figured out
I am now using Vista 32bit laptop T tryied it with a 64bit laptop and it did the same thing so i took it back to costco and got the 32 bit version I realy want to use Freestyler but I cant seem to get it up and running
Thanks ,
dj Mikey Mike
www.directsound.com
:o
Re: Error installing MAGIC 3D
install it manually?
its downloaded during installation maybe there is somethig wrong with your internet or theres
directsound
I understand that but Thats the error I keep getting upon instalation. I am on the internet see I am writing this post. I downloaded 3dvisulizer stright from there site but I cant get to interface with freestyler ether I need some help I cant think of anything else to do
Mike :x
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
error 404 is file not found.
Either they have moved the link or there download server is down.
The address http://www.nicolaudie.com/big/magic.exe does return a 404 error.
Send a message to raph so he can contact them and update if necessary.
Matt
PWES
Post by PWES »
I had the same issue, the trick seems to be download it direct from their site, and install it into the freestyler folder, having backed up 3 files
here's the solution from Raph, posted on this forum before:-
- Download Sunlite Easy View 3D ( http://www.nicolaudie.com/big/Magic.exe )
- Install FreeStyler and make sure you un-check the install Easy 3D option
- After finishing installation of FS, make a backup of the files: MEVP.dll, MEVP_VB.dll and DasHard2006.dll
- start the installation of Sunlite Easy3D, BUT INSTALL IT IN THE FREESTYLER DIRECTORY !!!
- Copy the files MEVP.dll, MEVP_VB.dll and DasHard2006.dll back in the FreeStyler folder
directsound
THank you I will try it out later today I hope this works! I will keep you posted.
Props,
DK Mikey MIke :D
directsound
Ok I did as told but there was only the one file in the folder MEVP.dll and I saved it to another folder then installed the 3d fills then reinstalled the one that was there but after FREESTYLER Loaded I LAUNCHED THE 3d program it opend but it didnt work any lights it seems like there is no DMx PATH TO THE 3D PROGRAM i WENT BACK TO LOOK AT THE FOLDER AFTER i INSTALLED THE 3D program and it now has one more file DasHard.dll but thats just a note any help I cant fugur it out
thanks Mike
paradoxism
Post by paradoxism »
Having the same issue - wiped down my computer and did a clean download and install of 2.96j and M3dEV. Both seem to load fine individually (Easy View in the Freestyler directory) but when I click the Easy View icon in FreeStyler nothing appears to happen.
Have tried seperate installs and installing Easy View manually but only one of the three files mentioned is in the new install (MEVP.dll).
I have had previous versions running fine together yesterday - any ideas anyone?
Cheers in advance
Paul
