Thanks in advance
No fixtures in mobile app
hex1
I have freestyler set up with a few fixtures and I have the paid version of the android app and if I select fixtures on my laptop I can change the colours perfectly fine however when I go into the fixtues tab, the ques tab or the overide buttons tab non of them are populated in the app although they are on my laptop, I am using version 3.4.6 on Windows xp (yes I know it's an old os that isn't supported any more but this laptop is very stable and it ain't broke so I ain't going to fix it
Thanks in advance
Thanks in advance
