I need more Channels/Fixture Topic is solved
Tow-B
Post by Tow-B »
I've bought 2 Eurolite LED-Bar 648/5 ... When i try to control every of the 8 LED-segments for nice effects i need 48DMX-Channel, Fixturecreator has
a maximum of 33 Channels..
Is there a Reason for the Channel-Limitation or would it be possible to extend this value?
A the moment i have to add 2 Fixtures a 24CH to control every segment..
thx and greets..
Tow-B
Re: I need more Channels/Fixture
because your using it in a way is not designed for as most lights would never have 32 or over channels! imagine controlling a moving head and you had to set 32 different channels just to get the light on.....
you'd have to use 2 fixtures like you are.
it would be pointless to increase this...
sorry! :D
Return to “Ideas and Remarks”
