Checking my work
halfbright
I Use FreeStyler for: Theater
Checking my work
Post by halfbright »
Awhile back I created a profile for Kryo.mix CMY made by Blizzard. What I got works but I do not think I got things completely right. Here is a link to the page where you can down load the manual, (come in a PDF format) -> https://www.blizzardpro.com/products/kryo-mix-cmy
Also Attached is the export of what I created. I did the 28 channel version but not the 21, or 23 channel.
Thank you for any and all help
Halfbright
KRYO.MIX CM.pff
(93.75 KiB) Downloaded 21 times
Re: Checking my work
Post by Jan_K »
Hej.
I just had a quick look at you fixture and it is a bit complex to review.
If I look at the color wheel "1st colorch" is 7 and "Cyan Ch." is also 7. I think one of them is wrong.
"2nd. colorch." is 8 and "Magenta CH." is also 8.
"Lamp channel" that is normal for igniting the bulb so I would delete that entry.
"Shutter ch" think I would change that to channel 26. But I think that is a bit more how do you want the control to work.
On the "Strobe ch." the high value is 255. Think that I would limit that to 223 and then use macros to place the fader in the right value range.
