Eurolite TMH-75 Hybrid / Varytec GYVER Laser Topic is solved
Chris3875
Hello, i am searching a Fixture for the TMH-75 Hybrid Moving Head and for the Varytec GYVER Laser.
Greets Chris
Greets Chris
- FreeStyler Version: 4.1.7
Re: Eurolite TMH-75 Hybrid / Varytec GYVER Laser
Is the attached PDF the user manual for your instrument?
Chris3875
Yes, this is my Moving Head
Attached is my attempt at a fixture definition for your light.
There are 2 dimmer channels, one for the COB and one for the HCL. The standard sliders are labeled but Freestyler is unaware that these are dimmer channels (Freestyler only supports 1 dimmer channel).
Color wheel 1 controls the COB
Color wheel 2 and the Color window controls the HCL
Please test and provide feedback
Chris3875
Hello, thank you I will try ist asap. and give you a feedback
Chris3875
Hello, the fixture works so well. Makros, Sound to Light, Gobo change etc. works perfect but how do I turn on the Light of the Lens and the LED Ring?
Greets Christian
Greets Christian
Thank you for the feedback.
The COB LED dimmer is controlled by channel 12 which is labeled COB LED dimmer in the standard sliders. Select the fixture, the standard sliders should appear in the upper right hand corner. Move the slider to 100% and, hopefully, you will see light.
Channel 21 is the dimmer for the HCL LED and the standard slider is labeled HCL LED dimmer. I suspect that at least one of the color dimmers will also need to be set to a value other than 0. Ex. set the HCL White slider to 100% and then slide the HCL LED dimmer to 100% - this should produce a white light.
Chris3875
Ok, many Thanks
fsuser
Hallo, what about the GYVER Laser fixture? Anyone has it?
