NEED Fixture File for Antari Z series 2 1200 Fogger Topic is solved
DJ RIOT
Anyone have file fixture for a Antari 1200 Fogger??????
MarSafe
Re: NEED Fixture File for Antari Z series 2 1200 Fogger
HI, DJ Riot,
You can use anything that uses 1 DMX-channel. Your Z1200MKII use only 1 channel to turn the smoke on or off. No intensity, no fancy stuff. In the standard fixtures there's also a Z1500, you can use that one. That's what I did, anyway.
Regards,
Martin.
Regards,
Martin.
- djSupport
so in short if he had researched this himself he wouldn't have needed to post this as he could of made it himself or used common sense? Let this be a lesson to you all!
