Led Wash Zoom 36x12 RGBW
gremlins4x
FreeStyler Version: 3637
Post by gremlins4x »
Dear friends,
I need your help for Led Wash Zoom 36x12 RGBW fixture. I didn't find anything match till now.
Here is the DMX channels manual.
Thank you.
Led Wash Zoom 36x12 RGBW.pdf
(180.15 KiB) Downloaded 57 times
gremlins4x
Re: Led Wash Zoom 36x12 RGBW
Please help me.... Thank you.
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Attached is a fixture definition that may work.
The documentation is unclear about:
CH6 - what is total light adjustment
CH14 - what is Self-proprelled mode
CH15 and CH16 - what are these?
Please test and provide feedback.
Chinese LED Wash Zoom 36x12 16ch.pff
(28.89 KiB) Downloaded 50 times
gremlins4x
Thank you very much. I try and add what means channel 06,14,15 and 16.
gremlins4x
Please help.
I need your help for Led Wash Zoom 36x12 RGBW fixture and the file ssl2 for scan library or 3d easy view. Thank you.
Channel 6 is - You can choice second channel to adjust brightness.
manual led wash zoom 36x12.xlsx
(10.85 KiB) Downloaded 26 times
manual led wash zoom 36x12.pdf
(70.44 KiB) Downloaded 33 times
gremlins4x
This is original manual. I gave the manufacturer a requirement to elaborate a detailed manual. Thank you.
I need ssl2 and fixture please. Thank you....
Led Wash Zoom 36x12w.pdf
(308.46 KiB) Downloaded 32 times
gremlins4x
I created a new file for this product. Maybe I'll help someone.
Led Wash Zoom 36x12w.ssl2
(13.81 KiB) Downloaded 41 times
