Hi, i want to add midicontrols to the pans and tilts of my scannermirror.
It works fine, but only in a on/off command.
How or where can i set this for a full gradual movement of the mirror?
Is there also maybe a setting to be specified for this in the fixture configuation (fixture creator)?
Midi command tilt/pan
- remco_k
- FreeStyler Version: N/A
Re: Midi command tilt/pan
FreeStyler->Setup->External Control->Midi control
There are several options for pan/tilt. I think you need to assign to 'pan 8bit channel' and 'tilt 8bit channel' to a midi fader (or rotator or whatever you use).
