DMX 400
Fetenjung
DMX 400
Post by Fetenjung »
Hallo Zusammen,
leider ist mein Englisch nicht so gut, daher hoffe ich Ihr könnt mir trotzdem helfen. Ich bin auf der Suache mit dem DMX 400 mehr als nur 8 geräte anzusprechen. Habt Ihr da ne Idee wie ich das machen kann???
Gruß der Fetenjung :fs:
MarSafe
Re: DMX 400
Post by MarSafe »
Translation:
Hi, everyone,
Unfortunately my English isn't very good, but I hope someone can help me. I'm looking for a way to control more than 8 fixtures with the DMX400. Does anyone have a clue how to do that?
Greetings from Fetenjung.
What I do now is having more dimmerpacks set to the same DMX-channel. You can shift them some channels so that that fourbar isn't doing the same thing as one other. Expanding the number of channels isn't possible as far as I know.
Ich hab genau das problem mit Deutch im Schrift. :D Ich habe jetzt mehrere Dimmerpacks eingestellt auf gleiche DMX-kanale. Sie konnte das pack 2 oder mehr kanale schieben, so das 2 4-bars nicht ein gleiches patron haben. Mehr als 8 kanalen sind nicht moglich.
Android Dev (Moderator)
FreeStyler Version: BETA
Re: DMX 400
Post by Mattotone »
The maximum channels for the dmx400 is 8.
Fetenjung
Re: DMX 400
Post by Fetenjung »
Sorry for my English!!!
Is there no way to add more channels??? Maybe in a new software version?
Re: DMX 400
Post by Mattotone »
Theres no current way for users to add channels,
You may request for more channels to be added in the appropriate thread.
But the way the sequences are made are not dynamic and would require all to be redone for the new channels.
A request could be for dynamic sequences that users can make and would auto scale for 512 channels.
Matt
FreeStyler Version: 4.01
Re: DMX 400
Post by Partyman »
You can have more than 1 light on each channel
Rusty
Fetenjung
Re: DMX 400
Post by Fetenjung »
How????
MarSafe
Re: DMX 400
Post by MarSafe »
I've explained this before: You can always set more dimmerpacks to the same channels. If you use (for example) 4 four-channel dimmerpacks and the first one starts at DMX-channel 10, then the second one starts probably at 13. If you set the other 2 packs also on startchannel 10 and 13, these packs will do exactly the same as the others. You'll have 16 lights controlles by 8 DMX400-channels.
Re: DMX 400
Post by Mattotone »
Alternatively, soft patch them to the same channel, then if you do want to control them individually you can remove a channel from the patch, without having to go into the rig and readdress your lighting.
You then also don't have to have all your channels of your dimmer shadowing another just the channels you need.
Matt
