I want something simple
ezzhelmy
FreeStyler Version: 3.6.49
I Use FreeStyler for: Theater
Twitter: https://twitter.com/ezzhelmy
Post by ezzhelmy »
hi
I need Programming fader for red par led and fader for green par led and... to play the show Manual.
I need explained to do it
JDawg
Re: I want something simple
Post by JDawg »
What fixture? Find out what channel is red/green from the owners manual.
What midi controller? Map the fader of your midi device to control the above channels.
Check the wiki, you'll eventually find out what you need.
ezzhelmy
Post by ezzhelmy »
I need record 3 Submasters
1 for red
1 for green
1 for blue to play the show Manual
i use led bar
i controller from laptop
i Check the wiki and dont find it Because it is simple
FreeStyler Version: 4.1.6
Post by Rod_Horning »
Please EXPORT (use the Fixture Creator) the fixture definition for you instrument(s). From there we probably can obtain the information needed to assist you.
Is the attached PDF the user manual for your instrument?
ezzhelmy
Post by ezzhelmy »
you do not understand me
i want record 3 Submasters or more . not cues Just Submasters to play the show Manual
Yes, I understand what you are asking for. Without the requested information we can not assist you.
However, there will be cues involved as that is what is loaded into the submasters
ezzhelmy
Post by ezzhelmy »
Rod_Horning wrote: 12 May 2019, 00:04 Yes, I understand what you are asking for. Without the requested information we can not assist you.
Absolutely
this is the my problem
i need submasters without cues
That is not the way Freestyler works. You either load a sequence or a cue list into a submaster. The sequence can be a single step, for example to set a color.
ezzhelmy
Post by ezzhelmy »
Rod_Horning wrote: 12 May 2019, 01:48 That is not the way Freestyler works. You either load a sequence or a cue list into a submaster. The sequence can be a single step, for example to set a color.
i do it
single step red in sequence into a submaster
single step green in anther sequence into a submaster
but all sequence Works With some
Thank you anyway
