varytec hero Spot Wash 80
nomic
Post by nomic »
Hi you all.
needing very mutch of your help.
lookingo for fixtures do varytec hero Spot Wash 80
apreceate you help.
you all :fs:
FreeStyler Version: 4.1.7
Re: varytec hero Spot Wash 80
Post by Rod_Horning »
Hello,
Is the attached PDF the correct manual for your instrument?
If so, in which mode are you interested?
Regards
Varytec Hero Spot Wash 80 2in1 RGBW.pdf
(1.95 MiB) Downloaded 52 times
nomic
Post by nomic »
Rod_Horning wrote: 20 Apr 2019, 02:46 Hello,
Regards
Yes it's that one
the 20ch mode.
i have ben trying to build one on my one... but strangling on the part of controlling spot and wash with diferent dimmers.
Big thanks on your help
Attached is my attempt at a fixture definition for your instrument.
Please test and post any issues - I will attempt to correct any problems.
Your instrument is actually 2 instruments in one - wash and spot. The wash function has separate dimmer and strobe controls from the spot function. Sometimes the best way to define such an instrument is to define multiple fixtures so that the various functions are represented by a fixture. Due to the DMX channel structure of your instrument I choose to keep everything in one fixture definition - thus BLACKOUT will not turn off the lights in your instrument and I did not define a strobe channel. These functions are controlled from the standard DMX sliders - the helpful programming windows for these functions are not available.
Programming windows that ARE available:
Beam
Colors
Gobos
Macros
Custom Sliders
Pan/Tilt
Varytec Hero Spot Wash 2in1.pff
(183.75 KiB) Downloaded 58 times
nomic
Post by nomic »
Many thanks
this is my ideia...
i am very new on building fitures.
what do you think about this??
varytec_hero_spot_wash_80.pff
(122.51 KiB) Downloaded 47 times
nomic
Post by nomic »
have just tested yours and the one i put.
both work. but mine seams more complete.
i would apreciate any input on both of them and some improvements
I noticed that your version does not have labels for 3 of the channels. You may find that a bit confusing during programming. Also, while certainly not a problem, I did not see the gobo shake values in the gobo wheel.
As you have made the effort to build a fixture definition you will probably find it easier to use the one you built as you are more familiar with it.
nomic
Post by nomic »
Rod_Horning wrote: 21 Apr 2019, 12:56 I noticed that your version does not have labels for 3 of the channels. You may find that a bit confusing during programming. Also, while certainly not a problem, I did not see the gobo shake values in the gobo wheel.
i'll improve with that feedback.
Many thanks on all your help.
after the update i'll put the new fixture here.
