Creating a chase with LED Parcans
DJNuance
FreeStyler Version: 2.95f
Post by DJNuance »
I think this is probably easier than I think and I am over complicating it.
I currently have 6 Chauvet LEDRAIN 38's These are 7 channels fixtures
1 - RED
2 - GREEN
3 - BLUE
4 - Macro Colors (by LED levels)
5 - Strobe or Speed
6 - Preset Programs
0-127 No Function
128-159 Fade Program: use Channel 5 to adjust Speed
160-223 Color Chase: Use Channel 5 to adjust speed
224-255 Color Chase: Use rotary knobt adjust speed
7 - Dimmer
I am not looking for any too complicated. We are doing basic weddings but just want to be able to create a sequence so the chase would be possibly 2 lights on at a time and every change would change the color
eg.
1 & 4 red
then
2 & 5 Green
then
3 & 6 Blue
and continue
most complicated thing is i would like to be able to control the speed manually
I can create override buttons to be al a certain color or blackout.
Is there away the DMX400 can be used for this??
any help would be greatly appreciated.
Thanks!
Rob
DJNuance
Re: Creating a chase with LED Parcans
Post by DJNuance »
I got it working. i think
I still had 2.95 installed I installed the new version and then had to reset the correction in the freestyler options. for some reason everything was set to 255 and nothing was controllable.
it seems to be working fine now.
Thanks!
