Path not found
Taske
Path not found
Post by Taske »
Hello,
sometimes I had an error saying " Path not Found " and so, since I had a saved show I didnt bother, since when i load it, everything was alright again.
Now I need to do a new patch for a small gig on friday with different rented lights
Everytime i try to add fixtures i get the message for example "Plastic LED.fxt : Path not found: "C:/FreeStyler/Fixtures/"
Mostly it happens with custome made fixtures, but also with premade like the sharpys.
When i delete all lights and want to add for example 8 LED-Pars it allows me to add 1, and the remaining ones are shown some "empty" in the fixture list
to be sure i didnt messed up the fixtures i upload all my custome mades.
If there is someone who had a similiar problem, or knows whats going on, im in a little bit in trouble.
Edit:
OS: Windows 8.1
Freestyler: 3.6.49
notebook: Lenovo Thinkpad x201t
Plastic LED.pff
(444 Bytes) Downloaded 27 times
LED DimRGB.pff
(358 Bytes) Downloaded 30 times
Garage LED.pff
(423 Bytes) Downloaded 26 times
6x40W LED BEAM ZOOM WASH.pff
(858 Bytes) Downloaded 28 times
FreeStyler Version: 4.1.7
Re: Path not found
Post by Rod_Horning »
I am running 3.6.49. I downloaded and Imported your 4 fixture definitions and then added them to the Freestyler workspace. I did not encounter the Path Not Found issue.
The fixtures do not have a picture. Is this a possible source of your issue?
In the Freestyler directory you should find a file named freestyler.ini. Open and look for the lines starting with the text remember (ex. remember1 and remember1_file). See if these are correct - if not then delete these lines and save the file.
Schuim
FreeStyler Version: lates
Re: Path not found
Post by Schuim »
Copy your Chases, Fixtures, Locations and Que folder to a safe location, uninstall, install the latest version, add/merge the folders and you should be alright.
Had this problem with older versions where somehow paths were messing up for some reason. Even with the files their selves still available on the disks.
