ADJ Mini Dekker - how to program a "motor" channel?
djharryg
Commited FS Forum helper
FreeStyler Version: 3635
Post by djharryg »
I've been using this fixture file. But, it does not give me the ability to "move" the lights. Or rotate them. etc.. I cannot figure out how to program the motor channel. Help!
Mini Dekker.pff
(9.46 KiB) Downloaded 23 times
Freestyler: V3.6.35
FreeStyler Version: 4.1.7
Re: ADJ Mini Dekker - how to program a "motor" channel?
Post by Rod_Horning »
This question is to verify I understand your issue. If you select the fixture and then use the standard Freestyler slider (which is not showing in your attached picture) for channel 7 (Motor Control) your fixture does not move? The fixture file does not have channel 7 as a PAN or TILT channel so Freestyler does not provide that programming window for you.
