need profile Aiweidy a-6209 Topic is solved
perac1989
Post by perac1989 »
Hi ppl, i‚m new in freestyler software...relatively in all off this, i‚m working in most way weddings and disco light
Can somebody make, or upload if he have profile for led par 54x3 aiweidy 6209
channels are...
0 - intensity
1 strobe
2 red
3 green
4 blue
5 function
6 speed
7 white
Thanks a lot
FreeStyler Version: 4.1.7
Re: need profile Aiweidy a-6209
Post by Rod_Horning »
Attached is a fixture file for you to test. If you can provide more information about the various functions the fixture definition might be able to be improved. Once you import the fixture and add it to the Freestyler workspace and select it click on Window_> All to display the various helpful Freestyler programming windows.
Aiweidy A6209 Par.pff
(22.79 KiB) Downloaded 18 times
perac1989
Post by perac1989 »
Thanks for upload, i will try it tomorow morning...
