Background Size Topic is solved
daba
Background Size
Post by daba »
Newcomer to here, newcomer to Freestyler, newcomer to DMX....
I have set a .jpg as my Background picture, but it has come in way too large and I'm only seeing part of the "stage".
Is there a way to resize it ?
If I can't resize it, I want to delete it, and can't find a way to do that either.
Please help me get a bit further up the learning curve...
FreeStyler Version: 4.01
Re: Background Size
Post by Partyman »
The file is located in a folder C:/Freestyler/Ui Interface/backgrounds (i think) just go in there and delete any files you wish. Your background image should be the same resolution that your monitor is set to use
daba
Re: Background Size
Post by daba »
No such folder - the background was chosen from my Dropbox "Camera Uploads" folder, so I deleted it from there and it has gone in Freestyler, with no complaints that it could not find the file.
