Spoilers
Android Dev (Moderator)
FreeStyler Version: BETA
Spoilers
Post by Mattotone »
A few spoilers coming in the next release!
Presets, save a signal fixtures or all fixtures attributes such as position, colour, gobo etc to be recalled to any scene in a cue. Change the preset and will automatically update the cue.
Shape tool, seems the bugs are fixed and works the way we wanted.
NEW graphics, menu bars , scroll bars, buttons, and icon looks pretty ;).
FS now indicates which fixtures are currently in a scene when creating a cue.
Windows can now be reset to their default position! No More lost windows.
Fades are shown when previewing a sequence in the cue creator, and can be disabled I.e All become snap to view scenes.
backups will now only restore saves from the current version, Unfortunately meaning no more backwards compatibility for locations but removes the out of bounds error.
Folders can now be removed from the save scene/cue manager.
Point Open Play -> Now allows a cue to be selected open and played straight from the insert sequence window in the cue manager.
Cue list buttons, saved cue lists from the fast cue switcher can now be assigned to a button, and will play all the cues in the list when the button is selected.
Removed message boxes which could pause the program.
Sequence name in cue fixed when added with save dialog.
Bug fixed with midi and mousecursor, selecting and locking to adjusted parameter via midi.
Bug fixed with overrides not allowing changes until channel was released .
Cue Player updated, more friendly GUI.
Should be coming soon Currently 2.98E
ayoungman
Re: Spoilers
Post by ayoungman »
That all sounds great. I've been using FS a lot recently. I ran a large stage for 10 days with live bands each night. Quite a big rig consisting of moving heads, parcans via dimmers, leds etc etc. No real problems at all. I can't wait for the updated version. Thanks fellas for all the hard work that has gone in to this software. Cheers from Alan
cantyco
Re: Spoilers
Post by cantyco »
Currently 3 days into a 5 day event that we are struggling with some of these mentioned bugs, can't wait to get hold of the new version so no more of these annoying bugs,
Good Work Ralph! Keep up the hard work, it's very much appreciated of all the time you spend develping the software!!!
:fs:
Richard Mills
Re: Spoilers
Post by Richard Mills »
I agree! I can't wait to see a new UI and some additional development to this incredible software. Well done and keep up the great work!
J.J.
Re: Spoilers
Post by J.J. »
I too am looking forward to the new software.
I ran into problems with 2.96j. Thanks for the update.
bckeeping
Re: Spoilers
Post by bckeeping »
Any idea when we can get our hands on this pile of loveliness? :)
Great product that keeps getting greater :)
Re: Spoilers
Post by Mattotone »
probably when raph believes the known bugs have been ironed out.
J.J.
Re: Spoilers
Post by J.J. »
Do you need any BETA testers? I want to create a 1 page pdf advertising the new features. Maybe even some How To video's for my website to help DJ's.
Re: Spoilers
why not create some tutorials on here
lj_raph
FreeStyler Developer
FreeStyler Version: 3.2.1
Re: Spoilers
Post by lj_raph »
Hi
If you find a bug or a problem,PLEASE REPORT IT !!!
It's the only way to make FS bugfree.
If you have problems with the current version and you want to try the latest beta just send me an email with the problems you are having and I will send you the latest beta.
Best regards
Raph
Raphaël
Re: Spoilers
Post by LJ_krede.dk »
HEY
I am dying to know when version 2.98E is released.
I have the primary responsibility for a light show to a party at Aalborg University, Denmark, the 1st of november.
I would be happy to use/test the new version and give back some respond if u want the version fully tested.
I also have reorted a bug about tab sync button not always working, and can test that also, when that is fixed.
dmx light to be controlled by Freestyler:
6x Martin PAL1200 FX, Scanner
3x Futurelight MH-640, Moving-Head Washlight
1x Futurelight MH-660, Moving-Head Spot
1x Eurolite TS-7b, Sacnner
4x Elation Pro Bar 4, 4 channel DMX dimmer pack with 4 individual DMX addresses
1x Lite-Puter DX625, DMX 6CH. Dimmer Pack
/LJ_krede.dk
cantyco
Re: Spoilers
Post by cantyco »
Was wondering if any idea on a date yet?
i have a gig 15th of novemeber that really would be helpful to have the new version without some of the current bugs that have been fixed in the new version.
any ideas?
aquas
Re: Spoilers
Post by aquas »
I ppl, i've tested a new version and... i think Ralph is working hard to put a new stable version online but, some problem ocure during when i test a beta...so don't worry, whating compensates. congratulations to Ralph.
cumpr
lj_raph
Re: Spoilers
Post by lj_raph »
Ok guys
We are currently testing a new beta which will become (I hope) the next release.
Here's a complete list of all the added functions:
- Some UI changes (new icons, colors)
- Added a new touchscreen UI
- Added new password security
- Added a simple sequence generator (sine, cosine and saw)
- Added "Ignore blackout" function
- Added "quick save" for saving sequences
- Added "disable all other buttons" in overridebuttons
- Clone fixture function added
- Up to 12 fixtures can be controlled by the DMX400
- Disable/enable fixture (no values are send to that fixture)
- Disable/enable playback fixture (no playbackvalues are send to that fixture)
- Added select next, previous, even and odd fixtures (keyboard and midi shortcuts)
- Added LOCATE function to locate fixtures (you can configure custom values in the profile)
- Icon added on fixture when override active
- Indication during sequence creation if a fixture is actif in a sequence (yellow= actif, red= actif with preset values)
- Added some new programs to the DMX400
- Added play cuelist buttons: save a cuelist and play that cuelist with one button !
- Added option to reset windows positions
- 16bit pan & tilt fades
- Added 60 presets
- Import/Export sequences and cues for uploading to a Martin 2510 controller (Martin "Download to 2510" tool needs to be installed)
Enhancements:
- Changed Freeze and blackout behaviour
- DMX400 settings are saved
- Some improvements in the DMX400
- previous location files and backups are refused (most problems were caused by old files)
- Removed Winamp synchronization because of limitations
- Sequences are no longer compatible, but can be converted by opening and saving them in the sequence editor.
- General enhancements
- Many bug fixes
Raphaël
cantyco
Re: Spoilers
Post by cantyco »
:fs: All them features sound great, good work Ralf!
if you need any further testers let me know, would love to try the new version.
Tim
