Hi Wonder if enttec wings controller works with Freestyler?
https://www.enttec.com/products/control ... back-wing/
ENTTEC WINGS Topic is solved
- djSupport
Re: ENTTEC WINGS
What does this have to do with the FreeStyler wiki?
uffeulander
Re: ENTTEC WINGS
Jag undrade om freestyler funkar bra med Enttec ving....
Vad skulle det vara för fel på den frågan???
- FreeStyler Version: Beta
Re: ENTTEC WINGS
Yes Freestyler supports Enttec wings but am not sure about the model you are referring to.
You can find more Enttec wing information on the wiki.
I think what djsupport means if that this area are for wiki related issues.
Think I would have posted it under Freestyler software.
