Bezier Shapes or Fixture File
adamj812
FreeStyler Version: X2
Post by adamj812 »
I have a generic LED Movin head Spot that I'm working with. I try to use the bezier shapes, but they look nothing like what's on the screen. I suspect it may have to do something with the fixture pan/tilt not lining up with the software. It has a 540 pan and a 270 tilt. Where would I set the zero in the software so the bezier grid is correct?
FreeStyler Version: 4.01
Re: Bezier Shapes or Fixture File
Post by Partyman »
you would have to make sure that the fixture file is setup with the correct degrees in the slots for pan and tilt range
adamj812
Post by adamj812 »
I have the correct degrees set up, but I'm thinking the fixture PAN 0 is different than where software is starting. The rectangle in the software looks more like a figure 8 when running.
Post by Partyman »
moving heads dont always do the shapes the way one would think
