Not sure if this is a Fixture Creator or a Freestyler issue.
Dealing with some Chinees lights, made up the fixtures in Fixture creator, and they work the first time through.
I save the show, and when I open it back up, I get a "path not found" for the fixtures I made.
not saving fixtures? Topic is solved
RatmanMiff
RatmanMiff
Re: not saving fixtures?
attached is the set-up screen- -its all there, have no issues adding lights
I save the Freestyler file, and come back to it, and some of the lights are missing, and it has that "file not found error"
on the PDJLT50's I did pull a generic fixture pic in, but didn't with the others - does it have to have a pic?
RatmanMiff
Self Resolved solution.....Evidently you need to associate an Image with the fixture you create!
Once i did added a picture (i just went through all the fixture pics and picked something that looked close), it worked great, saved the show, re-opened, and it was all still there!
keanhong2
- FreeStyler Version: 36.34
yeah ,,,your Fixture image just paste it into FS folder C:\FreeStyler\Fixtures
