Sinde shortly i extended my light equiptment with some new lights. As my touch screen is pretty small, i decided to start using pages in the touch UI. Some of my override buttons are set as "page independent" but unfortunately i cant see the state anymore from that moment. This means i cannot see if they are active or not. This is very sad as this results in situations where i want to activate a button which is already activated (so it will be disabled) or visa versa.
My question is if i'm doing something wrong or is this a bug?
Thanks in advance!
Page independent override buttons does not show state
lightman1990
- FreeStyler Version: 3.6.3
- djSupport
Re: Page independent override buttons does not show state
It could be a bug, report it and let the developer investigate it, it may take a while though
doctorzorro
- I Use FreeStyler for: Eurovision
The releasebuttons always were a bit weird. I always made the releasebuttons exist on page 1, 2, and in my case 3. So not as "page independant" but multiple pages.
The latest release seems to have fixed it, it works fine on version 3.6.49, even when releasebuttons are pageindependent. If it doesn't work, try the above.
Red lights are bad for ya, mmkay?
