I have quite an unusual light to integrate into Freeestyler, its a 4 in 1 unit purchased from eBay.
https://www.ebay.co.uk/itm/60W-4-in-1-P ... 2749.l2649
Has anybody done something similar before?
I'm thinking of having to just create a bunch of sliders and playing to see exactly what each value does as its not very clear from the documentation...
Here's the settings:-
1 GOBO 0-24 Gobo off
25-255 Gobo colours
2 0-9 Light Off
10-44 Red - Yellow
45-79 Green - White
80-114 Blue - UV
115-149 Red, Green, White, Green
150-184 Green, Blue, White, UV
185-219 Red, Blue, Yellow, UV
220-255 Red, Green, Blue, White, Yellow, UV
3 Laser 0-9 Laser Off
10-99 Laser - Red
100-199 Laser - Green
200-255 Laser Red & Green
4 Strobe 0-9 Strobe Off
10-255 Strobe Speed
5 0-16 1, 2, 3, 4 Channel mode
17-33 1ch Mode
34-50 2ch Mode
51-67 3ch Mode
68-84 4ch Mode
85-101 1-2ch Mode
102-118 3-4ch Mode
119-135 2-4ch Mode
136-152 1-4ch Mode
153-169 1-3ch Mode
170-186 2-4ch Mode
187-203 1-2-3ch Mode
204-220 1-2-4ch Mode
221-237 1-3-4ch Mode
238-255 2-3-4ch Mode
6 GOBO 0-9 Gobo - Motor Off
10-127 Gobo - Motor Speed
128-255 Gobo - Motor Speed
7 0-9 Motor Off
10-255 Motro Speed
8 Laser Motor 0-9 Laser - Motor Off
10-127 Laser - Motor Speed
128-255 Laser - Motor Speed
9 Mode 0-50 <BLANK>
51-150 Auto
151-255 Sound Mode
Chinese 4 in 1 unit - anybody done something similar? Topic is solved
- FreeStyler Version: 4.1.7
Re: Chinese 4 in 1 unit - anybody done something similar?
Channel 5 is confusing. Have you determined anything?
Blue407
I have had a play with it, managed to work out most things. I will find my notes and write them up
deckardX
- FreeStyler Version: 3.6.51
Here is one I made. It's a bit rough but gets the job done. The only thing I left out were the counter-rotations. Also, I set up rotation speeds as buttons instead of sliders since I don't really like using sliders.
Marygel_4in1.pff- (92.14 KiB) Downloaded 34 times
