Hi there, I have a small problem. I've created cuelist buttons to run different cuelists. But, when I click on another cuelist button the running one freezes. When I click again on the one that is running, it will play again. Is there anyone who knows what I'm doing wrong?
Explain: 1 cuelist button I have running a sequence with my movingheads. another button is the laser.
When I am running button 1, the moving heads are running. But when I click on the next button 2, the moving heads stops and the laser is running.
And reverse so first button 2 and then button 1, is the same. But then the movingheads are running, and the laser stops (pause/freeze). So there must be something why the rest stops.
									Cuelist pauses
				djdacore
 - FreeStyler Version: 3.5.2
 - FreeStyler Version: 4.01
Re: Cuelist pauses
There are options under the cog wheel in the cue window and another in the cuelist window. Each list has different options for what happens in cue windows. I believe you want to select Cue multiselect always enabled
