help with RGB chinese uplight Topic is solved
naim_the_dream
Post by naim_the_dream »
I am having issues finding a profile for my Chinese RGB par light.. here is a photo of it... if anyone can help me with a profile for it I would appreciate it
https://drive.google.com/open?id=1w1Bcs ... VsBY787o5r
FreeStyler Version: 4.1.7
Re: help with RGB chinese uplight
Post by Rod_Horning »
Can you tell us anything more about the light. Or, best, post the user manual? Short of that you can do the trial and error method of determining the DMX channel usage.
