white/red cross
stompinne
white/red cross
Post by stompinne »
Hi, i included a new fixture in my line up.
Created a first sequence with it...worked nice.
Till now...
In the fixture image a white/red cross appears now
And the blue color of a channelslider is not blue anymore but green.
This "green channel" also doesn't react anymore on changes with the sliders/settings of the fixture
What's happened, what can i do
(10.32 KiB) Not downloaded yet
Re: white/red cross
Post by Jan_K »
That Icon normally means that you have disabled the fixture.
But it is normally placed in the other side of the fixture image
The disable function is in the menu that pops-up when you right click on the fixture.
Try check that
