Docooler / TataYang / U'King Moving Head Fixture-File Topic is solved
stancecoke
Post by stancecoke »
Hi there, im completely new to this topic. I've buyed a moving head from amazon. It's sold with several different brands.
I tried to create my own file using the fixture creator, but it is not selfexplaining :-(
Here is the description from the manual:
Is there an existing fixture file that works with this device?
I found a 7 channel setup, but the channel adresses are different to my manual.
OK, I managed to build a basic setup for the 13 Channel mode. The Channels 5 -12 (LED1-8) are defined as custom sliders. You have to set the device to 13 Channel mode (second menu entry) ...
regards
stancecoke
Docooler RGBW Moving head.pff
(5.21 KiB) Downloaded 48 times
