I've got 2 MinSpots on my truss. Programmed the first one to move in a square (the preprogrammed FS movesments make the MS's move in a pattern other than described). First one worked fine so I added the second MinSpot to mirror the first one on the other side of the stage. When I ran the sequence the 2nd one worked fine while the first one moved in the right patter it just shifted itself to the stage left about 90 degrees so it no longer mirrors the second MS.
Any thoughts?
Help with moving heads
