How do I create a cue Topic is solved
fincaman
Hello All, I have installed Freestyler and added my fixtures, because my needs are simple and my fixture is of unknown make I have added 3 par 56s Red Green and blue how do I get them to appear in the submasters so I can control them and make a scene/cue
- FreeStyler Version: 4.01
Re: How do I create a cue
You really need to read the wiki for basic info then come back with questions afterward. How to make a cue and use submasters is well documented in the wiki
Mateo123
Apologies to everybody!
Finally figured everything out...dug deep into freestyler wiki and found what I was looking for
Sorry everyone for being annoying,cheers
Please start your own thread and quit hijacking every thread. Also please add the file you are working on so others can help you find your mistakes
fincaman
Hello Partyman, thanks for your help Didn't know about the WIKI instructions I have done that and got a bit further. I've Created a fixture and two sequences (spent all day yesterday on it) can't see any mention of creating a cue list but I'll keep trying
You insert the cues into the cue window using the cog wheel at the top of the cue window. You can then save the cue lists the same way. Make sure to set the attributes of that cue (right side of cue list) before saving.
fincaman
Thanks again but I have another stumbling block when I select one of my fixtures (I now have 3) then click window/all I get nothing, if I add a commercial fixture all the windows pop up, I am obviously doing something wrong when creating my fixtures, I'll look for instructions about creating fixtures
When creating a fixture file you can be very basic (just insert channel labels) or you can be very elaborate giving you windows and buttons for every aspect of that fixture. I suggest you open 1 of the commercial files in the Fixture Editor and see the differences in how they are setup.
scott823
- FreeStyler Version: 3.6.51
When I add a scene to a cue, the moving lights move but the lights don't work. Help! Thanks.
