Hi Guys,
I am having an issue with S2L triggering across multiple loaded sequences.
So I have a few sequences loaded into the queue list, all running.
Some are movements, some are shutters, colours etc.
I have the settings in the quelist buttons set so that the shutters should respond to S2L, but the movements are disabled.
However, on each beat everything seems to be jumping and responding, rather than just those chases set to do so.
Is this a bug, or is there something I have missed in settings?
Anyone else had this?
Kind Regards
Ben
Having a challenge with S2L trigger settings - is it just me?
- FreeStyler Version: 4.01
Re: Having a challenge with S2L trigger settings - is it just me?
In the S2L window make sure you checked "jump to next step" NOT "Random DMX value"
I am pretty sure that this is set correctly as it would have been the first thing I would have checked. I'll take a look tonight though, just in case.
That would be embarrassing
