running location files on different windows OS
- Commited FS Forum helper
- FreeStyler Version: 4.6
Hello, quick question for the experts, I have a couple different pc's that I am using FreeStyler with, a laptop and a desktop at a venue, is it possible to take a backup from the pc running windows 10, and install it on a pc running Vista, as long as the FreeStyler versions are the same, and use it? (my usb to dmx works better at the one place with Vista) Thanks in advance!
- FreeStyler Version: 4.01
Re: running location files on different windows OS
Should work regardless of version. worst case scenario is install latest version before installing backup
Great, thanks for the info, just figured I would ask before I traveled over there. I really appreciate the input!!
