Is it possible to make a scene/single click macro from selected submasters?
lynxus
FreeStyler Version: 3.6.4
Post by lynxus »
Hi Guys,
Quick Q.
Say you have 5 submasters.. Movement, colors, gobos etc etc
is it possible to select a preferred setup.. Then save as "Cool Submaster Mashup 1" etc
Id like to use my submasters as an easy way to create scenes.
Then have say, press key 1 for scene1 , key 2 for scene 2 etc..
Maybe its done a different way by mixing the cues and saving as something else somehow?
Maybe its not possible or im thinking about this the wrong way.
Any thoughts would be epic!
Cheers
G
lynxus
Re: Is it possible to make a scene/single click macro from selected submasters?
Post by lynxus »
Turns out im being stupid.. figured it out.. just save them as a cue.
My next question is.. can you play two cue lists at the same time? (one list for one set of lights.) another for others,,,
FreeStyler Version: 4.01
Post by Partyman »
yes by using cuelists instead of submasters
