Scroller programming problem Topic is solved
Sparkybob
Post by Sparkybob »
Tying to run an ancient unlisted scroller with Freestyler 2 -3.6.47. Only way I have found is to use "Dimmer Rack" and 1 channel . In create sequence I need to load each step of a 15 step sequence with a different DMX level number but cannot get all values on the slider. SMX levels needed are 0-15 in steps of 1. there has to be a better way. I have looked at "fixture creator" but I only want to use one channel? bit stuck so some hel[p please.
FreeStyler Version: 4.01
Re: Scroller programming problem
Post by Partyman »
Really would like to help but am having much difficulty understanding what: Fixture you are work with, and what you are wanting to do with it
