Microh Firefly RGB Laser - Profile needed Topic is solved
djelvislee
Post by djelvislee »
Hello folks, just wanted to know if anyone has created or could create a profile for a Microh Firefly RGB Laser. I have tried to create one using the Fixture Creator 6.1, however when creating a custom fixture, I can only see 4 tabs: (Fixture Config., Channel Description, Macros, RGB Segments. There is no place that I can configure each channel and its DMX values. Could someone help?
Please see manual attached for this laser.
Thank you kindly!
firefly_rgb.pdf
(659.61 KiB) Downloaded 19 times
