din control cable
cantyco
FreeStyler Version: 2.96h
din control cable
Post by cantyco »
Hey guys,
i need to get some cable to make some din cables up, anybody know what type of cable i need and where sells it?
Or anybody know of a good place to buy pre-made din cables?
cheers
Android Dev (Moderator)
FreeStyler Version: BETA
Re: din control cable
Post by Mattotone »
try cpc.co.uk they will stock every component you will need to make your din cable.
the cable type will depend on how many pins your din has.
cantyco
Post by cantyco »
its an 8pin din
can i just quickly ask what its for?
cantyco
Post by cantyco »
Got a couple of dimmers i use that arn't dmx, so i have a demux except for an event would be handy to seperate the dimmers too different places, and since i only have one demux i need to get longer control cables for between the dimmers and demux.
aha it's just I have a din cable that needs replacing on a martin smoke machine (it goes from the smoke machine to the dmx box) and I don't know the pin out and cant work it out as its physically broke....
cantyco
Post by cantyco »
what smoke machine is it?
Post by Mattotone »
cantyco wrote:what smoke machine is it?
not sure its not at my house I'd love to get irt working its either the heater or that...
its a martin/jem
when i go over i'll let you know
