I'm using a 3rd party USB-DMX interface with the DMXKing interface selected and I'm seeing a constant stream of bursts on the DMX lines when probed with an o-scope even when I have not output enabled.
Is this normal? Is there a way to turn off all DMX output?
I created a custom fixture for RGB PAR lights and I'm trying to debug the signals but its impossible with all this DMX traffic on the lines.
Thanks, Steve.
Constant Output on DMX lines
srotyliano
- FreeStyler Version: 3.6.4
- I Use FreeStyler for: Band
- remco_k
- FreeStyler Version: N/A
Re: Constant Output on DMX lines
Might just be a (bad) cable issue. Try and change some cables, and try to connect a terminator to see if the problem changes or dissapears.
