Trying to create a fixture file for the ADJ Pearl WH and am having some trouble.
Got the fixture to light but the high and low strobes are inversed when I click the buttons in the lamp box within FS.
Other issue I have is how to I code the rotation in the fixture creator? Values are
Rotation Channel = 2
Rotate left 10-120 (Fast to Slow)
Rotate Right 125-245 (Slow to Fast)
Stop 0-9, 121-134 and 246-255
ADJ Pearl WH
- djSupport
Re: ADJ Pearl WH
stick that channel in a focus or iris on the FC if your not using that then in FS you'll have a slider when clicking the focus etc window
Re: ADJ Pearl WH
Worked perfectly, thanks.
- djSupport
Re: ADJ Pearl WH
don't forget to export you fixture and upload it for the community!
