RGBW and RGBWA Led Lights
mobilegreg
Just started using FS
FreeStyler Version: 3.0.1
Post by mobilegreg »
Can anyone tell me if the color mixing pallete will utilitize the White and Amber Leds automatically when mixing colors on fixtures that have that option. I have several that have the white led, but I have to manualy use the white color control instead of choosing white in the color control window. I will soon be adding a few with Amber as well. Not sure if maybe I need to set the fixture up differently or have a setting I neeed to change. Just trying to simply the process.
FreeStyler Version: 4.01
Re: RGBW and RGBWA Led Lights
Post by Partyman »
I am pretty sure that the addition colors (white, amber, UV, ...) are not utilized in the color pallete
sukebe
FreeStyler Version: 3.4.6
Post by sukebe »
Can you get the color pallete to work?
I have a little pinlight from china (Smuxi 10W DMX RGBW LED Stage Light Pinspot)
Which is alot like Blizzard Lighting's 10W LED pin spot, but that profile does not change the colors, just the 'gobos' (color patterns).
Post by Partyman »
please post the manual or dmx layout for your fixture
