2nd monitor touchscreen issue Topic is solved
MiroslavCZE
Post by MiroslavCZE »
Hello!
I have notebook (ThinkPad T440p) - 1st display in windows and external monitor with touchscreen (EliteDisplay E230t) - 2nd monitor in windows. In other programs is all working perfectly, but when I run Freestyler touches from 2nd monitor are showed on monitor 1!
I tried almost everything including edit of ini file,
[Touchscreen]
Enabled=1
Display=2
but without expected result. Can anybody help me?
MiroslavCZE
Re: 2nd monitor touchscreen issue
solved, pls delete this.
Laudrin
FreeStyler Version: 3.6.49
Post by Laudrin »
Please tell us how you solved the problem, so that other users can learn from it when they stumble across the same problem. Thanks! :-)
