Kam Kmh1 Topic is solved
Forbes789
Kam Kmh1
Post by Forbes789 »
so far i have successfully got my mega pars and fusion spots working but i cant find a fixture for my kam kmh1 tried to create a fixture for them i gave it a bash but really struggling to get it to behave as it should
anyone able to help out
https://whybuynew.2dimg.com/resources/1416932874_28.pdf
alanv
Just started using FS
FreeStyler Version: 3.63
Re: Kam Kmh1
Post by alanv »
What do you want the ligth to do? Mobile DJ, Stage lighting, etc?
First thing to do is use Freestyler or a standalone unit and Map the DMX channel and value for each channel in the DMX range you want to use. Please remember i do not have the fixture to test it so your feedback will be required. I use Excel to map the dmx values and their color/function. Tilt and pan does not need to be mapped, just the dmx channel.
Please post your try at the fixture creation so i can have a look.
If in doubt, look at viewtopic.php?f=73&t=7682&p=29968&hilit ... 7CH#p29968
I have posted a fixture map there in excel. If you can do that I will be able to help.
greets
ace
Forbes789
Re: Kam Kmh1
Post by Forbes789 »
Its a mobile disco setup
Basically So far freestyle is set up with 2 x equinox fusion spots and 4 x mega par profiles which have the fixtures set and all working and controlling via dmx.
I can't find a pre made fixture for the kam kmh1s so tried making my own following a guide on here but not getting much response from the unit I can get open and close and white led. I'll give it another try and have a look at that link see if I can get anywhere
alanv
Re: Kam Kmh1
Post by alanv »
Hi bud,
Try this for a start and lemme know.
Kam KMH1.pff
(52.19 KiB) Downloaded 35 times
