Hi All, still very new to freestyler, however can't figure out how to do this.
I have got 5 chases that last 5 minutes each (one for each type of fixture), Lets call them chases A B C D and E.
I want them to play in the order below:
1st) B & C Together
2nd) D & E Together
3rd) A & B Together
4th) C & E Together
5th) B & D Together
6th) A & C Together
Then loop over from 1st and so on.
How do I do this? I will ultimately want to save it to my Entec USB Pro MK2 for standalone use without a computer.
Regards: Elliott.
How to play sequence of chases together?
- FreeStyler Version: 3.6.4
- I Use FreeStyler for: Bedroom Lighting.
- FreeStyler Version: 4.01
Re: How to play sequence of chases together?
You will not be able to load more than 1 scene to the dongle (no sequences, must be a static scene with no color changes). Anything that changes will have to be run through the sequence window via cuelists or submasters. You can build a cuelist that has all the sequences above and select them to run concurrently. You will need to consult the wiki or youtube vids for assistance in building the cuelist
