This is from the old forum
Malhim
lighting
hi ther
ive purcahsed a velleman usb controlled dmx interface and a mojo spinmaster III
the stand alone test for both the interface and dmx light fixture is working
however, i do not know which dmx dip switch settings i need 2 turn on and off on the dmx light fixture in order 4 it 2 communicate with the usb controlled dmx interface
plez cud u tell me?
and
plez cud u tell me an operation 2 perform on the demo lightplayer software?
e.g. set dmx value to ... on channel 1
" " " " ... " " 2
etc..
and then what effect/output 2 expect
ive bought this roduct from my local maplins dealer andthy have told me 2 contact u
thank you
plez reply 2 me as soo as possilbe at mlmalhi@gmail.co.uk
thnx agen
DJ Support
did the mojo spin master come with a manual??? maplins should of sold you one with a manual!
DJ Support
if you turn dipswitch one up or on then that is the address you enter into freestyler when you add the mojo spinmaster to freestyler then once thats done when u select a colour/gobo etc the light should react some lights have the option to turn dipswitch 10 on/off to select dmx mode which is where u'd have to turn to the manual!
USB Controlled DMX interface
- FreeStyler Version: 3.01
- Twitter: http://twitter.com/jaykie
