Chinese Moving Head (Docooler 60w Moving Head)
storer77101
Just started using FS
Post by storer77101 »
Hi All,
A while back I purchased a cheap moving head from amazon
https://www.amazon.co.uk/gp/product/B01 ... =UTF8&th=1
It is pretty good for the money and has DMX functionality. I had been able to program it on my analogue controller however since moving to freestyler I can't seem to work out how to do it, I have had a go and nothing works. I would be really grateful if someone could look at making a fixture file for it, I have attached a picture of the DMX settings that were in the manual.
ps in the manual there is a hole in the paper where one of the values are it says 190-193.
TIA :fs:
Kind Regards
Daniel
FreeStyler Version: 4.1.7
Re: Chinese Moving Head (Docooler 60w Moving Head)
Post by Rod_Horning »
Thank you for posting the manual pages.
Attached is my attempt for the 11 channel mode.
The manual, likely due to language translation, is not clear on channels 7 and 8 so they may be incorrect.
The colors (channel 5) are not defined in the manual pages. The link you provided did list the colors so I guessed at the color to DMX value.
No gobo pictures were available so I just used 1, 2, 3 ... 8.
Please post any corrections and/or additional information and I will update the fixture definition.
After you add the fixture to Freestyler and select it, click on the top menu item Window->All. In addition to the standard Freestyler sliders this will open the following helpful programming windows:
Colors
Gobos
Lamp
Macros
pan/tilt
custom sliders
I expect I do not have the fixture completely correct so please provide feedback so that the fixture definition can be improved.
Docooler_60W_LED_moving_head_11ch.pff
(132.74 KiB) Downloaded 71 times
storer77101
Hi Mate,
Thank you so much it is spot on, life saver.
Kind Regards
Daniel
