Hello Friends, I would like to be able to join 2 sequences in Freestyler, I mean. Suppose I create a sequence that controls 6 mobile heads doing an effect with the Fx generator (what appears in sequence creator) and I create another sequence that controls 4 more heads also using the Fx generator but another effect, the question is: how can I join those two sequences so that I appear in the cue list as one and not have to give play to both at the same time.
Thank you...
Freestyler secuence
joseph90
- FreeStyler Version: 3.5
- FreeStyler Version: 4.01
Re: Freestyler secuence
Create the first sequence then make sure you are on the last step before adding the next effect OR if you want them to fire at same time then return to first step when creating the new effect. Make sure you deselect the first fixtures and select the second movers before applying new effect
joseph90
It work perfectly thank you very much Partyman. It really had not occurred to me to do that. Thank you so much.
