Led spider 18/48 channels Topic is solved
zilvinaslt12
Post by zilvinaslt12 »
Hello,
Maybe someone can help to create freestyler fixture. Adding manual.
thanks
FreeStyler Version: 4.1.7
Re: Led spider 18/48 channels
Post by Rod_Horning »
Attached is a generic 42 channel fixture. It is defined with RGB segments - 1 row, 8 segments.
If you can provide more detail about the Effects and Color effects channel and the M1 and M2 channels I might be able to enhance the fixture to make it easier to use.
If you can provide a better picture of your instrument I will update the definition.
Generic_LED_Spider_42chan.pff
(3.24 KiB) Downloaded 137 times
