Multiple foggers but need separate control Topic is solved
garnet2
Post by garnet2 »
I have a fogger and a hazer on different DMX addresses. They both are being controlled by the fogger control in Freestyler. I assigned a hot key of #9 and pressing this key toggles both units at the same time. How do I control them separately??
FreeStyler Version: 4.01
Re: Multiple foggers but need separate control
Post by Partyman »
set buttons for individual control the same way you would for a light.
garnet2
Post by garnet2 »
I need to control them both with a hot key. I use these during a fast moving show and the fog and haze have to be on demand. I understand changing the profile to control them separately but I don't know how to hot key an individual light/source???
PhantomDj
Has mastered Fixture Creator
FreeStyler Version: 3.6.49
Post by PhantomDj »
Create an override button that you manually set the desired DMX values for fog and haze machine, and use that button to control them instead of the native FOG/Haze window UI
PS: Most likely you would want to set that button as a Flash button and not as a toggle as well
