Execute more than one sequence at same time?
- FreeStyler Version: 3.6.4
It's possible execute two or more sequence at the same time? For example a dimmer sequence and a pan/tilt sequence? or a pan sequence and a tilt sequence?
- FreeStyler Version: 4.01
Re: Execute more than one sequence at same time?
There is an option to allow multiple sequences to run. It is in the cue window, click the gear icon and it will be in the drop down menu
- FreeStyler Version: 3.646
Yes, as Partyman wrote it, you have the control of it in the gear, you can toggle it by midi control pad and in the setup menu => freestyler setup => preference => extrat options, you had an "cue multiselect always enabled" option.
I am a newbie but it's seems to be the most efficient and powerfull way to do what you want. You can combine basic sequence into a cuelist that you can launch and stop with button at the right of the cues.pautore wrote: 16 Jul 2018, 23:19For example a dimmer sequence and a pan/tilt sequence? or a pan sequence and a tilt sequence?
Speak English / Parle Français.
Actually running submasters would be the way for you to go if you want to run in the way stated above
"It would be" it the right term.
The fact is that the cue's parameter are reset when you load a new sequence from submaster. You can't prepare parameters in the submaster before launching.
When you change multiple cue's that must use the same parameters as the last cue, you always have to change it quickly. A little annoying.
