Hi All,
I have just started using freestyler and have tried to make the fixture file myself but have had no luck. I would really appreciate if someone would create it for me I would be extremely grateful. Thanks in advance and I have attached the manual in the post
Kind Regards
Daniel
HQ Power Galaxy 250
storer77101
- Just started using FS
- FreeStyler Version: 4.1.7
Re: HQ Power Galaxy 250
Attached is my attempt. Please test and provide feedback.
After you select the fixture click on the top menu item Window->All. This will open the Freestyler helpful programing windows.
HQPOWER_VDP250MH62_6ch.pff- (88.09 KiB) Downloaded 14 times
storer77101
Hi Sorry for the slow reply. Thank you so much this worked perfectly.
No problem. Thank you for the feedback. I am glad it worked.
