Lazerworld el-100g
apophyss
Lazerworld el-100g
Post by apophyss »
Fixture for this lazer.
Tell me bugs.
el-100g.pff
(3.2 KiB) Downloaded 146 times
stompie
Re: Lazerworld el-100g
Post by stompie »
Werkt dit ook voor de EL-40G van lazerwolrd ?
FreeStyler Version: N/A
Post by remco_k »
stompie wrote:Werkt dit ook voor de EL-40G van lazerwolrd ?
Welkom op het FreeStyler support forum. Hoewel je hier best in je eigen taal mag posten, kan je het beter in het engels doen gezien de grote hoeveelheid nationaliteiten hier.
So, I'll translate your question for the other readers here:
Does this also work for the Laserworld EL-40G?
Let be backfire a question for you: what do you think?
I seems to me that in about 10 seconds work, you can answer this question for yourselves.
Look up your DMX channel description in the manual and the DMX channel description for the el-100g, compare them and you will have your answer. (They need to be the same, most of the time)
On the other hand; just try it out.
blaguite
Post by blaguite »
I have just created this fixture and it is perfectly functional;)
el-100g.pff
Laserworld El-100G
(65.94 KiB) Downloaded 89 times
Return to “Lasers”
