I know other fixture files on here exist for the Chauvet Motion Drape, but here is my one.
If using programs 1-15, make sure channel 7 is set to 0. Equally is using programs 16-30, make sure channel 6 is set to 0.
This is because whatever program channel out of 6 (Programs 1-15) or 7 (Programs 16-30) was first or last successfully set to a program, effectively disables the other program channel in the process until the active program channel no longer has a program selected. Program channels are also disabled if channel 1 is >007.
Also included is a Zip file what contains high resolution JPG's of all the patterns along with the led.dat file that is on the SD card inside the controller. Have not yet been able to work out how this led.dat file works.
Fixture File:
JPG's & led.dat file: https://goo.gl/TCWTQp
Regards: Elliott.
eveares
Re: Chauvet Motion Drape
A small fix to the Fixture File. See attachment.
Regards: Elliott.
Regards: Elliott.
